2023-01-20 08:29 AM
Hi!
I have tested this in all my projects.
I have several compilation flavours with several symbols but you can test this issue only with default flavours: Release and Debug.
This symbol is not used and isn't a problem but in my projects and flavours I want not this symbol because may be confused to others developers. I can solve it by creating flavours based in Release but I would like to know if there is any option to avoid this behaviour
Thanks!!
2023-01-20 08:43 AM
No option. Hardcoded behavior if debug type build configuration.
As workaround possibly remove original Debug configuration and create a new one based on Release type
Takes care starting from Release type, compiler optimizations are not debug compliant so you will have to set them to proper values
2023-01-20 08:43 AM
2023-01-20 08:48 AM
Thanks a lot!! I was going crazy... hahah
