Use SD Card/ FATFS
‎2024-04-16 12:43 AM
Good morning,
I am looking to write data in csv format to my SD card with an SD shield. So I activate the SDMMC1 port and the FATFS driver for my SDMMC1 port, when I generate I then have 300 errors on my HAL header. Do you have any idea what the problem is, and how to solve it, please? THANKS.
Best regards,
STM32CubeIDE
‎2024-04-17 02:45 AM
I found the cause of the problem but I don't understand it very well. Before configuring the IOC for my SD, I created two files: a header and a source to manage my recordings I called them SD.h and SD.c, deleting these files no more problems...
I would like to thank you for your support and the speed of your responses.
Best wishes,
‎2024-04-16 01:15 AM
Could you please attach your ioc file?
‎2024-04-16 01:20 AM
‎2024-04-16 01:38 AM
‎2024-04-16 07:40 AM
Actually when I compile this project I don't have any errors. However, when I compile the entire project I get the following error message:
‎2024-04-16 07:54 AM
Now you're saying that the project compiles without errors? Did you solve it and now you're talking about another issue? Could you please clarify the situation?
‎2024-04-17 12:55 AM
Good morning,
Excuse me, it's really not clear!
When I compile the project you attached, I don't get any errors after compilation.
On the other hand, with my project I still have 300 errors.
The IOC is the same, where can the problem come from?
Thank you for your valuable help.
Best regards,
‎2024-04-17 01:26 AM
I didn't make any change on your ioc file.
Or simply compare the content of your folders and mine. It could be there is something related to the generated driver files: missing header or c file.
Or it could be something related to the path of your project (AFAIK windows have max 256 character per path length). Try to put your folder directly on C drive root. Remove spaces in the path.
Best wishes,
