Unable to write to microcontroller with stlink-v3minie
baby_chicken
When I try to write to stm32h742vgt6 using stlink-v3minie, Target is not responding, retrying... and cannot write.
The same microcontroller can be written to the board on which it is mounted. In the same program.
What are the possible outcomes in this case?
Is it just a bad solder or something else, or can you give me a few possibilities?
Thank you in advance.
symptoms↓
Failed to reset target.
Waiting for debugger connection...
Debugger connected
Shutting down...
Exit.
3 REPLIES 3
Show your connections.
What do you mean by that?
What board is it?
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
This is a home-made board using stm32h742vgt6.
It is not NUCLEO etc.
Best regards.
Show the schematic of the board.
What do you mean by, "The same microcontroller can be written to the board on which it is mounted" ?
