UART is not working
‎2024-03-20 12:34 PM
I have checked connections and assured that everything is set up correctly. When I run the below code, I cant see anything on serial console.
Does anyone have any idea about the root cause ?
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
* @attention
* Copyright (c) 2024 STMicroelectronics.
* All rights reserved.
/* USER CODE END Header */
#include "main.h"
/* Private includes ----------------------------------------------------------*/
#include <string.h>
#include <stdio.h>
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
RTC_HandleTypeDef hrtc;
UART_HandleTypeDef huart2;
/* USER CODE BEGIN PV */
RTC_TimeTypeDef RTC_TimeRead;
RTC_DateTypeDef RTC_DateRead;
/* USER CODE END PV */
static void MX_RTC_Init(void);
static void MX_USART2_UART_Init(void);
/* USER CODE BEGIN PFP */
char* getDayofWeek(uint8_t number);
char msg[200] ={0};
char msg2[200]={0};
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init();
MX_RTC_Init();
MX_USART2_UART_Init();
/* USER CODE BEGIN 2 */
char *msg4 = "message4\n\r";
HAL_UART_Transmit(&huart2, (uint8_t*)msg4,strlen(msg4),1000);
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
char *msg3 = "message3\n\r";
HAL_UART_Transmit(&huart2, (uint8_t*)msg3,strlen(msg3),1000);
HAL_RTC_GetTime(&hrtc, &RTC_TimeRead, RTC_FORMAT_BIN);
HAL_RTC_GetDate(&hrtc, &RTC_DateRead,RTC_FORMAT_BIN);
sprintf(msg,"current time is: %02d:%02d:%02d\r\n",RTC_TimeRead.Hours,RTC_TimeRead.Minutes,RTC_TimeRead.Seconds);
HAL_UART_Transmit(&huart2, (uint8_t*)msg,strlen(msg),1000);
HAL_Delay(1000);
sprintf(msg2,"current date is:%02d-%02d-%02d-%s\r\n",RTC_DateRead.Month,RTC_DateRead.Date, RTC_DateRead.Year,getDayofWeek(RTC_DateRead.WeekDay));
HAL_UART_Transmit(&huart2, (uint8_t*)msg2,strlen(msg2),1000);
HAL_Delay(1000);
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
void SystemClock_Config(void)
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_LSE;
RCC_OscInitStruct.LSEState = RCC_LSE_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
RCC_OscInitStruct.PLL.PLLM = 8;
RCC_OscInitStruct.PLL.PLLN = 50;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4;
RCC_OscInitStruct.PLL.PLLQ = 7;
Error_Handler();
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
Error_Handler();
* @brief RTC Initialization Function
* @PAram None
* @retval None
/* USER CODE BEGIN RTC_Init 0 */
/* USER CODE END RTC_Init 0 */
RTC_TimeTypeDef sTime = {0};
RTC_DateTypeDef sDate = {0};
/* USER CODE BEGIN RTC_Init 1 */
/* USER CODE END RTC_Init 1 */
/** Initialize RTC Only
hrtc.Instance = RTC;
hrtc.Init.HourFormat = RTC_HOURFORMAT_12;
hrtc.Init.AsynchPrediv = 127;
hrtc.Init.SynchPrediv = 255;
hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
if (HAL_RTC_Init(&hrtc) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN Check_RTC_BKUP */
/* USER CODE END Check_RTC_BKUP */
/** Initialize RTC and set the Time and Date
sTime.Hours = 0x12;
sTime.Minutes = 0x11;
sTime.Seconds = 0x10;
sTime.TimeFormat = RTC_HOURFORMAT12_PM;
sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
sTime.StoreOperation = RTC_STOREOPERATION_RESET;
if (HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BCD) != HAL_OK)
Error_Handler();
sDate.WeekDay = RTC_WEEKDAY_TUESDAY;
sDate.Month = RTC_MONTH_JUNE;
sDate.Date = 0x12;
sDate.Year = 0x18;
if (HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BCD) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN RTC_Init 2 */
/* USER CODE END RTC_Init 2 */
* @brief USART2 Initialization Function
* @PAram None
* @retval None
/* USER CODE BEGIN USART2_Init 0 */
/* USER CODE END USART2_Init 0 */
/* USER CODE BEGIN USART2_Init 1 */
/* USER CODE END USART2_Init 1 */
huart2.Instance = USART2;
huart2.Init.BaudRate = 115200;
huart2.Init.WordLength = UART_WORDLENGTH_8B;
huart2.Init.StopBits = UART_STOPBITS_1;
huart2.Init.Parity = UART_PARITY_NONE;
huart2.Init.Mode = UART_MODE_TX_RX;
huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart2.Init.OverSampling = UART_OVERSAMPLING_16;
if (HAL_UART_Init(&huart2) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN USART2_Init 2 */
/* USER CODE END USART2_Init 2 */
* @brief GPIO Initialization Function
* @PAram None
* @retval None
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/*Configure GPIO pin : PA0 */
GPIO_InitStruct.Pin = GPIO_PIN_0;
GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
/* EXTI interrupt init*/
HAL_NVIC_SetPriority(EXTI0_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(EXTI0_IRQn);
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
char* weekday[] = {"monday","tuesday","wednesday","thursday","friday","saturday","sunday"};
return weekday[number-1];
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
__disable_irq();
while (1)
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @PAram file: pointer to the source file name
* @PAram line: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
‎2024-03-22 2:04 AM
This is what I suggested him in my first comment in this thread.
@demir Could you please close this thread by selecting one of the comments that solved your UART problem? or give the solution here and close it after?
‎2024-03-20 12:57 PM
which board ?
custom/ which cpu ?
What you connect to ---> usb ?
‎2024-03-20 1:52 PM
Are you sure the code is running?
Can you toggle a GPIO/LED at the same time?
Configuring the right pins, code not shown, connectivity not diagrammed. Hard to diagnose with the imagination.
Can you look at the signals with a scope?
‎2024-03-20 11:00 PM
I have added HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_14) to check if code is actually running, you are right that it doesnt run at all.
* @file : main.c
* @attention
#include "main.h"
#include <string.h>
#include <stdio.h>
char msg[200] ={0};
char msg2[200]={0};
* @retval int
int main(void)
HAL_Init();
MX_GPIO_Init();
MX_RTC_Init();
/* Infinite loop */
while (1)
HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_14);
HAL_Delay(1000);
HAL_Delay(1000);
HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_15);
* @retval None
Error_Handler();
Error_Handler();
* @PAram None
* @retval None
Error_Handler();
sTime.Hours = 0x12;
Error_Handler();
sDate.Date = 0x12;
sDate.Year = 0x18;
Error_Handler();
* @PAram None
* @retval None
Error_Handler();
* @PAram None
* @retval None
__HAL_RCC_GPIOD_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(GPIOD, GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15, GPIO_PIN_RESET);
/*Configure GPIO pins : PD12 PD13 PD14 PD15 */
GPIO_InitStruct.Pin = GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
* @retval None
__disable_irq();
while (1)
* @retval None
‎2024-03-21 12:16 AM
You need to debug your application. Put breakpoints where you suspect an issue or step by step your application it could be stuck in the Error Handler!
‎2024-03-21 11:02 AM - edited ‎2024-03-21 11:19 AM
Thanks for directing me in the right way. You re right, application is stuck at error handler while configuring system clock. Could you please check for me if I did wrong configuration for the clock ?
Error_Handler();
Error_Handler();
‎2024-03-21 11:24 AM
Tell us a little more about the board and chip you're using here. Lacking much in the way of context.
You can comment out the call to SystemClock_Config() and the chip will just keep running with the boot settings.
‎2024-03-21 11:25 AM
You still haven't told us:
- What chip you're using
- What board you're using:
- Is it an ST board? Give the name
- Is it a 3rd-party board? Give a link to specifications, schematics, etc
- A custom design? Give schematics
- How you're connecting to the UART
- Do you have an oscilloscope to check for signs of life?
‎2024-03-21 11:49 AM
Sorry guys.
My board is STM32F407VG-DISC1.
I am encountering an issue now that is I cant connect to the board. Please see the error I get below.
‎2024-03-21 12:46 PM
I have updated the ST Link firmware and issue disappeared. I can test that UART is working, I have just written a simple code to check and I can see via serial console that UART is fine.
On the other hand, the original issue still persists.
