STM32U5 - Enable MDF use ADC1 as data source
James613
Can anyone give me some hints how can I use ADC1 as data source for the MDF?
Thank you
STTwo-32
Hello @James613 and welcome to the ST Community .
I suggest you to put the Cursor on the greyed Command that set the ADC1 as data source for the MDF (as shown on your screenshot). A message will pop-up to indicate how to make this option available or why you can't configure it.
Best Regards.
STTwo-32
2 REPLIES 2
STTwo-32
Best Regards.
STTwo-32
Thank you so much!!!
I don't know this function before. I finally found that I need to change the conversion data management mode of ADC1 to MDF mode and the problem solved
