2024-06-08 03:08 PM - edited 2024-06-08 03:08 PM
Can anyone give me some hints how can I use ADC1 as data source for the MDF?
Thank you
2024-06-09 12:42 AM - edited 2024-06-09 12:43 AM
Hello @James613 and welcome to the ST Community 😊.
I suggest you to put the Cursor on the greyed Command that set the ADC1 as data source for the MDF (as shown on your screenshot). A message will pop-up to indicate how to make this option available or why you can't configure it.
Best Regards.
STTwo-32
Best Regards.
STTwo-32
2024-06-09 04:44 AM
Thank you so much!!!
I don't know this function before. I finally found that I need to change the conversion data management mode of ADC1 to MDF mode and the problem solved
