STM32H7B3I-DK - unable to flash code to board and enter debug mode
‎2024-02-21 7:07 AM
I am using 1.10.0 STM CUBE IDE. Everything was working fine until I unchecked the box to update STLINK firmware. Now it does not work. I later updated the firmware , but still not a thing changed. This is the message I get when I try to debug console:
STMicroelectronics ST-LINK GDB server. Version 7.0.0
Copyright (c) 2022, STMicroelectronics. All rights reserved.
Starting server with the following options:
Persistent Mode : Disabled
Logging Level : 1
Listen Port Number : 61234
Status Refresh Delay : 15s
Verbose Mode : Disabled
SWD Debug : Enabled
InitWhile : Enabled
Target no device found
Error in initializing ST-LINK device.
Reason: No device found on target.
Error in final launch sequence:
Failed to execute MI command:
target remote localhost:61234
Error message from debugger back end:
localhost:61234: Connection timed out.
I tried restarting a PC it did not help. Please help I need to finish my project.
- Labels:
Bug-report
STM32CubeIDE
‎2024-02-22 7:59 AM
I found a solution , it was a little switch on the board which switches beetwen SYS_MEM and FLASH. All it needs to be done is noted on here: https://community.st.com/t5/stm32cubeprogrammer-mcus/stm32h7b3i-dk-error-no-stm32-target-found/td-p/303802.
Thank for your time,
Regards,
‎2024-02-21 7:25 AM - edited ‎2024-02-21 7:25 AM
Which box you did uncheck?
And if you try to connect with STM32CubeProgrammer? what happens?
‎2024-02-21 7:49 AM
I just unchecked the option to not show me again that window(window for firmware upgrade) , now tried with Programmer I also can't connect. It even can't "see" the board as accessible, even tho it is powered on an control LEDs are blinking.
‎2024-02-21 7:50 AM
What message is showing with CubeProgrammer?
Could you please share a screenshot of the error?
‎2024-02-21 8:21 AM
‎2024-02-22 7:16 AM
Are you sure you didn't modify any option byte?
Are you sure you didn't make any HW change to the board?
‎2024-02-22 7:59 AM
Regards,
