STM32CubeIDE documents or instructions
dinhnguyen
I am new to this.  Are there  documents or instructions to set up a port using  ATM32CubeIDE? For example, if I want to set up an UART or USB port, what are steps that I need to do? what parameters that I need to set? I can't find any documents on this.
Thank you in advance.
6 REPLIES 6
Thanks.  I am new to both STM32CubeIDE and Programming Microcontroller.
And do you have any experience of programming in general ?
From the "getting started" link earlier - general microcontroller "getting started" resources:
https://www.avrfreaks.net/s/topic/a5C3l000000UYGFEA4/t145493?comment=P-1392529
I am a beginner.
No problem at all!  Here you can find help in both electronics and software aspects of your project and generally in software.  Good luck.
For a complete beginner with no prior programming experience, it might be better to start by learning the C programming language on a "normal" computer - away from all the added complications of embedded microcontrollers and electronics.
http://blog.antronics.co.uk/2011/08/08/so-youre-thinking-of-starting-with-c/
Or maybe on Arduino...
