STM32CubeIDE Version 1.13.2 and STM32H573
‎2023-10-26 12:05 AM
I am using the STM32H573 and GCC Version 7 in CubeIDE (MS Windows) for device debugging.
For debugging I am using:
- STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.externaltools.stlink-gdb-server.win32_2.1.0.202305091550\tools\bin\ST-LINK_gdbserver.exe
- GNU Tools ARM Embedded\7 2018-q2-update\bin\arm-none-eabi-gdb.exe
Now I am facing the problem that I do not see the SFRs (Menu: Window->Show View).
I configured the CMSIS-SVD Settings as following:
STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.productdb.debug_2.1.0.202306151215\resources\cmsis\STMicroelectronics_CMSIS_SVD\STM32H573.svd
This is included as "Device file" and "Custom file". Although I do not see any SFRs.
Can anyone help ?
‎2023-10-26 12:42 AM - edited ‎2023-10-26 2:59 AM
Hello @Box69 and welcome to the Community :),
I recommend you to follow the steps shared in this FAQ How to add or update the SVD file in different too... - STMicroelectronics Community Section 3.1 Add SVD file in STM32CubeIDE toolchain.
Please download the system view description from this link: STM32H573AI - High-performance, Arm Cortex-M33 with TrustZone, MCU with 2-Mbyte Flash, 640-Kbyte RAM, 250 MHz CPU - STMicroelectronics.
Please let me know if the issue is solved or not.
Thank you.
Kaouthar
Thank you.
Kaouthar
‎2023-10-26 4:45 AM
Hello @KDJEM.1,
thanks for your quick answer !
Unfortunately I could not solve the issue by following the steps as mentioned above. I tried also restarting debugger/application and updated file paths. Nothing helped.
Any idea what’s wrong ? Should I consider reinstalling the CubeIDE ?
‎2023-10-26 6:05 AM - edited ‎2023-10-26 6:05 AM
Hi @Box69 ,
Thank you for updating post.
"STM32CubeIDE Version 1.13.2 and STM32H573
I am using the STM32H573 and GCC Version 7 in CubeIDE"
-->The STM32CubeIDE1.13.2 support GCC 11 by default. Why did you change the GCC version?
Could you please try to reinitialize STM32CubeIDE1.13.2?
Thank you.
Kaouthar
‎2023-10-30 7:33 AM
I have it working now. The issue was that we only use CubeIDE for debugging. The build is handled by a tool called "scons." To make it work, I had to create a CubeIDE C++ project.
