startup object files missing
Knoor
hi all, new to stm32cube ide.
i generated all of the project files using the build in cubemx thing and written my program but when i press compile, make errors out on Startup/startup_stm32f407vgtx.o missing.
i've tried generating the files with a seperate cubemx installation but with the same result.
so i came to the conclusion: either my pc is not doing stuff or i missed a setting.
do you have any suggestions?
thanks in advance!
kars noordhuis
1 REPLY 1
mattias norlander
Sounds like Linker error. Linker unable to find the object file for the startup code. So is the startup code even compiled?
Can you post your full build console output?
