Something wrong with my gdb in stm32cubeide
‎2023-01-02 1:11 AM
When i run my code, something wrong with the gdb (like in the picture). Someone can help me pls?
- Labels:
STM32CubeIDE
STM32F4 Series
‎2023-01-05 2:18 AM
It is a normal behaviour when making run. If download is verified successfully, GDB session will be terminated that's why you see "terminated arm-none-eabi-gdb" in the debug window.
‎2023-01-02 1:44 AM
What's in the console?
‎2023-01-02 1:47 AM
It says download successfully, is it run properly or not (with terminated arm-none-eabi-gdb)??
‎2023-01-02 5:55 AM
Hello BAl K.1​ ,
At first , let me thank you for reporting your issue.
Could you please supply the gdb server log-file? It will be created if option “Log to file�? is enabled in the debug settings.
Regards,
Rim
‎2023-01-02 7:31 PM
STMicroelectronics ST-LINK GDB server. Version 7.1.0
Copyright (c) 2022, STMicroelectronics. All rights reserved.
Starting server with the following options:
Persistent Mode : Disabled
Logging Level : 31
Listen Port Number : 6123
Status Refresh Delay : 15s
Verbose Mode : Enabled
SWD Debug : Enabled
InitWhile : Enabled
COM frequency = 4000 kHz
Target connection mode: Under reset
Reading ROM table for AP 0 @0xe00fffd0
Hardware watchpoint supported by the target
ST-LINK Firmware version : V2J40M27
Device ID: 0x434
PC: 0x801d0dc
ST-LINK device status: HALT_MODE
ST-LINK detects target voltage = 3.22 V
ST-LINK device initialization OK
Stm32Device, pollAndNotify running...
SwvSrv state change: 0 -> 1
Waiting for connection on port 6124...
Waiting for debugger connection...
Waiting for connection on port 6123...
Accepted connection on port 6123...
Debugger connected
GDB session thread running
GdbSessionManager, session started: 1
Debugger connected
GdbSessionManager, session started: 2
Stm32Device, closeDevice() entry
GDB session, device event: 5
Stm32Device, pollAndNotify stopped
Stm32Device, closeDevice() exit
------ Switching to STM32CubeProgrammer -----
STM32CubeProgrammer v2.12.0
Log output file: C:\Users\brama\AppData\Local\Temp\STM32CubeProgrammer_a12800.log
ST-LINK SN : 066AFF363355373043093915
ST-LINK FW : V2J40M27
Board : 32F469IDISCOVERY
Voltage : 3.22V
SWD freq : 4000 KHz
Connect mode: Under Reset
Reset mode : Hardware reset
Device ID : 0x434
Revision ID : Rev A
Device name : STM32F469xx/F467xx
Flash size : 2 MBytes
Device type : MCU
Device CPU : Cortex-M4
BL Version : 0x90
Memory Programming ...
Opening and parsing file: ST-LINK_GDB_server_a12800.srec
File : ST-LINK_GDB_server_a12800.srec
Address : 0x08000000
Erasing internal memory sectors [0 6]
Download in Progress:
�������������������������������������������������� 0%
�������������������������������������������� 89%������ 100%
File download complete
Time elapsed during download operation: 00:00:06.721
Verifying ...
Read progress:
�������������������������������������������������� 50%
�������������������������������������������������� 100%
Download verified successfully
------ Switching context -----
Device ID: 0x434
PC: 0x801d0dc
GDB session, device event: 6
GDB session, device event: 3
GDB session, device event: 1
GDB session terminated: Client connection lost
GdbSessionManager, session terminated: 2
Received Ctrl-C from the client
ST-LINK device status: RUN_MODE
Device not halted(0), performing Ctrl-C
GDB session, device event: 4
Device halted
GDB session, device event: 0
GdbSessionManager, session terminated: 1
GdbSrv, last session terminated, signal dispose
Stopping port 6123
Received stop for port 6123, not accepting new connections.
GdbSrv, deInit entry.
Shutting down...
GdbSessionManager, deInit entry.
GDB session disposed: 2
GDB session disposed: 1
GdbSessionManager, deInit exit
SwvSrv deInit entry
Stopping port 6124
Received stop for port 6124, not accepting new connections.
SwvSrv deInit exit
Stm32Device, deInit success
GdbSrv, deInit exit.
Exit.
‎2023-01-02 7:32 PM
is that the gdb server log-file??
‎2023-01-03 6:42 AM
Hello BAl K.1,
Are you sure you are using the right debug button looks like you are using the run button?
‎2023-01-03 9:39 AM
Yes, i use run button, i want to run the code and that error appearing. is there any solution for that??
‎2023-01-05 2:18 AM
