AVerm.4
Retarget scanf on STM32G070RBxx Cortex M0+
(originally a reply to https://community.st.com/t5/stm32cubeide-mcus/retarget-printf-on-stm32g070rbxx-cortex-m0/td-p/720883)
Hi @Andrew Neil,
For the scanf do we need to make any other change?
My read function is-
int _read(int fd, char *ptr, int len){
 (void)fd;
 int i;
 for(i=0;i<len;i++){
 *ptr++ = uart_read();
 return len;
In the terminal window it is not taking any keypress.
    Pavel A.
    Pavel A.Best answer
    September 19, 2024
    setbuf(stdin, NULL);
    Andrew Neil
    I've not tried it.
    I guess you would still need to do the extern "C" and anything else specific to C++ ...
    AVerm.4
    AVerm.4Author
    @Andrew Neil
    This I'm trying on C. The cursor doesn't take input on keypress.
    Andrew Neil
    @AVerm.4 wrote:
    the cursor doesn't take input on keypress.
    What do you mean by that?
    Do you mean the keypress doesn't appear on your terminal?
    If you want that, it's called echo - it can be either local or remote:
    • Local - performed purely in the terminal itself
    • Remote - the echo is performed by your software.
    Again, beware of the line buffering.
    If you put a breakpoint in your _read function, is it hit ?
    Pavel A.
    Pavel A.Best answer
    September 19, 2024
