"Nothing to install." after trying to install IDE
Ksen.1
I had a problem with the IDE and deleted it by manually searching all the files on my ubuntu 20.04.
Now when I try to run the binary again, it says "Nothing to install.", however I have deleted all stm files from my machine.
What can I do?
Julien D
Looks like STM32CubeIDE is still part of the native package manager database.
To check this assumption you can use the dpkg command:
dpkg -l '*stm32cubeide*'
And then remove correctly the package using :
sudo dpkg -r st-stm32cubeide-1.x.x
Replace the version token 1.x.x by the one reported in first dpkg query.
HTH
2 REPLIES 2
Julien D
HTH
oeliks
Senior
Isn't there a uninstaller under installation folder opt/ ?
