NUCLEO-G491RE communication with SIMCom SIM800A - Problems
  • July 9, 2024
  • 5 replies
  • 2746 views
Hope you are doing good.
I am trying to transmit "AT" command using USART communication to SIM800A(SIM.COM).
I am facing errors, should I write a separate GSM module.
Thank you.
Best answer by Andrew Neil
@abhishek1991 wrote:
communication with GSM 800A - Steps Needed
Simple:
  1. Send valid AT command to the SIM800A;
  2. Receive reply from the SIM800A;
  3. Determine success/failure from the response, and proceed as appropriate.
I am facing errors.
What "errors", exactly?
Modular software is generally accepted as A Good Thing.
However, putting code which "has errors" into a separate module will just give you a module which "has errors" - it won't, in itself, solve your errors.
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
Andrew Neil
Andrew NeilBest answer
Simple:
I am facing errors.
My main code goes like this and below that is my usart code. I just want to transmit "AT" string get back OK from SIM800A. Can you please help me how to proceed further ?
Andrew Neil
You've marked my previous post as The Solution - but it seems this is not solved yet?
https://community.st.com/t5/community-guidelines/help-others-to-solve-their-issues/ta-p/575256#:~:text=If%20you%20accidentally%20chose%20the%20wrong%20post%20as%20solution%2C%20you%20can%20always%20revert%20this%20action%20by%20clicking%20%22Not%20the%20Solution%22
You still haven't said what were the "errors" you mentioned:
  • compiler errors in your code ?
  • "ERROR" replies from the SIM800A ?
  • other ?
Forget about the SIM800A for now - just connect your UART to a terminal.
Can you see anything being sent from your STM32?
Hi Andrew,
No, Not yet, I am working on it after usart is accomplished. Appreciate it. Thank you.
