live expression is not opening
Sushmita
Hey ST,
I was using cube IDE, after selecting  MCU board, we need to give project name,  while in targeted project type name i kept at  empty,  as i don't want to use IOC configuration.
After successfully  writing  and debugging the code ,  if I am   opening my live expression, or expression or SRF. its not opening .
let me know how i need to resolve this issue.
7 REPLIES 7
Imen.D
Hello @Sushmita ,
Which CubeIDE version are you using?
Did you trying edit live expressions while target is running?
Imen
1.12.1 version
yes
Imen.D
Hi @Sushmita,
This is a known limitation indicated in the STM32CubeIDE:STM32CubeIDE errata 1.1x.x :
Editing live expressions while target is running does not work with SEGGER J-Link.
Imen
I am not trying to editing the live expression, after debugging the code, live expression is not coming nor any expression. though I am  using the latest version of STM IDE.
Semer CHERNI
Hello @Sushmita
Could you share a screenshot of the IDE while you are debugging.
Also, could you please mention the OS installed in your machine.
Thanks,
Semer.
  I am trying to open live expression but its not. windows 11
1.12.1 version,
 I am not trying to edit the live expression. i just to want read my variables in live expression. But live expression is not opening.
