Is there a way to reset the STM32CubeIDE back to the initial setup?
‎2023-11-25 12:45 PM
Hi All,
Is there a way to reset the IDE back to factory setup? I've somehow manged to screw things up enough that it's really not workable anymore.
Thanks,
Richard
‎2023-11-25 1:49 PM - edited ‎2023-11-25 1:52 PM
if you just puzzled the windows or menus...
try:
>> To fix this, just remove this file inside your workspace:
>> .metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi
>> Hope this solves the issue.
if more complex ... delete/uninstall and install new.
(your projects in workspace will remain / stay the same , if you start using old workspace with the new IDE . )
try:
