I keep on running into -> void HardFault_Handler(void); When my HAL_TIM_PWM_Start_DMA(&htim1, TIM_CHANNEL_1, (uint32_t *) pwmData, index); Is called
‎2021-09-18 1:17 PM
Hi. I seem to get HardFault_Handler error when I start my HAL_TIM_PWM_start_DMA function.
I am not sure if it just gets stuck in an infinite loop in the while() called right after it.
This looks like allot of code but really its just 5 of my functions including main().
My TIM1 is set to Internal Clock and its on PWM Generator CH1 with Counter Period set to (80-1).
What could possibly be the reason for the HarFault?
#include "main.h"
TIM_HandleTypeDef htim1;
DMA_HandleTypeDef hdma_tim1_ch1;
static void MX_DMA_Init(void);
static void MX_TIM1_Init(void);
#define MAX_LED 8
#define USE_BRIGHTNESS 1
uint8_t LED_Data[MAX_LED][4];
uint8_t LED_Mod[MAX_LED][4];
int data_sent_flag = 0;
void HAL_TIM_PWM_PulseFinishedCallback(TIM_HandleTypeDef * htim){
HAL_TIM_PWM_Stop_DMA(&htim, TIM_CHANNEL_1);
data_sent_flag = 1;
void Set_LED(int LEDNum, int Red, int Green, int Blue){
LED_Data[LEDNum][0] = LEDNum;
LED_Data[LEDNum][1] = Green;
LED_Data[LEDNum][2] = Red;
LED_Data[LEDNum][3] = Blue;
void Set_Brightness(int brightness){
if (brightness > 45) {brightness = 45;}
for (int i=0; i<= MAX_LED; i++){
LED_Mod[i][0] = LED_Data[i][0];
for(int j=1; j<4; j++){
LED_Mod[i][j] = 90 - brightness;
uint16_t pwmData[(24*MAX_LED)+50];
void WS2812_Send(void){
uint32_t index=0;
uint32_t color;
for (int x = 0 ; x < MAX_LED ; x++){
color = ( (LED_Mod[x][1]<<16 | (LED_Mod[x][2]<<8) | (LED_Mod[x][3]) ) );
for(int y = 23; y >=0 ; y--){
if(color&(1<<y)){
pwmData[index] = 60;
} else {
pwmData[index] = 30;
index++;
for(int o = 0 ; o < 50 ; o++){
pwmData[index] = 0;
index++;
while(!data_sent_flag){};
data_sent_flag = 0;
int main(void)
HAL_Init();
SystemClock_Config();
MX_GPIO_Init();
MX_DMA_Init();
MX_TIM1_Init();
/* USER CODE BEGIN 2 */
/* USER CODE END 2 */
Set_LED(0, 255, 0, 0);
Set_LED(1,0,255,0);
Set_LED(2,0,0,255);
Set_Brightness(45);
WS2812_Send();
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
HAL_GPIO_TogglePin(GPIOC, GPIO_PIN_6);
HAL_Delay(1000);
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
* @retval None
void SystemClock_Config(void)
RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1);
/** Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.HSIDiv = RCC_HSI_DIV1;
RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV1;
RCC_OscInitStruct.PLL.PLLN = 8;
RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
Error_Handler();
|RCC_CLOCKTYPE_PCLK1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
/** Initializes the peripherals clocks
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_TIM1;
PeriphClkInit.Tim1ClockSelection = RCC_TIM1CLKSOURCE_PCLK1;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
Error_Handler();
* @brief TIM1 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN TIM1_Init 0 */
/* USER CODE END TIM1_Init 0 */
TIM_ClockConfigTypeDef sClockSourceConfig = {0};
TIM_MasterConfigTypeDef sMasterConfig = {0};
TIM_OC_InitTypeDef sConfigOC = {0};
TIM_BreakDeadTimeConfigTypeDef sBreakDeadTimeConfig = {0};
/* USER CODE BEGIN TIM1_Init 1 */
/* USER CODE END TIM1_Init 1 */
htim1.Instance = TIM1;
htim1.Init.Prescaler = 0;
htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
htim1.Init.Period = 80-1;
htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim1.Init.RepetitionCounter = 0;
htim1.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
if (HAL_TIM_Base_Init(&htim1) != HAL_OK)
Error_Handler();
sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
if (HAL_TIM_ConfigClockSource(&htim1, &sClockSourceConfig) != HAL_OK)
Error_Handler();
if (HAL_TIM_OC_Init(&htim1) != HAL_OK)
Error_Handler();
sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
sMasterConfig.MasterOutputTrigger2 = TIM_TRGO2_RESET;
if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK)
Error_Handler();
sConfigOC.OCMode = TIM_OCMODE_TIMING;
sConfigOC.Pulse = 0;
sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
sConfigOC.OCNPolarity = TIM_OCNPOLARITY_HIGH;
sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET;
sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET;
if (HAL_TIM_OC_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
Error_Handler();
sBreakDeadTimeConfig.OffStateRunMode = TIM_OSSR_DISABLE;
sBreakDeadTimeConfig.OffStateIDLEMode = TIM_OSSI_DISABLE;
sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF;
sBreakDeadTimeConfig.DeadTime = 0;
sBreakDeadTimeConfig.BreakState = TIM_BREAK_DISABLE;
sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_HIGH;
sBreakDeadTimeConfig.BreakFilter = 0;
sBreakDeadTimeConfig.BreakAFMode = TIM_BREAK_AFMODE_INPUT;
sBreakDeadTimeConfig.Break2State = TIM_BREAK2_DISABLE;
sBreakDeadTimeConfig.Break2Polarity = TIM_BREAK2POLARITY_HIGH;
sBreakDeadTimeConfig.Break2Filter = 0;
sBreakDeadTimeConfig.Break2AFMode = TIM_BREAK_AFMODE_INPUT;
sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_DISABLE;
if (HAL_TIMEx_ConfigBreakDeadTime(&htim1, &sBreakDeadTimeConfig) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN TIM1_Init 2 */
/* USER CODE END TIM1_Init 2 */
HAL_TIM_MspPostInit(&htim1);
* Enable DMA controller clock
__HAL_RCC_DMA1_CLK_ENABLE();
/* DMA interrupt init */
/* DMA1_Channel1_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA1_Channel1_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn);
* @param None
* @retval None
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(GPIOC, GPIO_PIN_6, GPIO_PIN_SET);
/*Configure GPIO pin : PC6 */
GPIO_InitStruct.Pin = GPIO_PIN_6;
void Error_Handler(void)
#ifdef USE_FULL_ASSERT
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
- Labels:
DMA
STM32CubeIDE
STM32G0 Series
TIM
‎2021-09-18 4:02 PM
Looks like you're writing to out of bounds arrays. Indices are 0-based in C.
Could be other issues. Look at SCB registers for the reason behind the hard fault.
Why don't you know if it's in a hard fault or in a while loop? Where is execution when you debug and pause the program?
‎2021-09-19 1:21 PM
@TDK​ Ok so I got it to not throw the void HardFault_Handler(void);
But now that I run the DMA in the while loop it crashes the second time.
Sometimes when I just run the code it can not talk to the debugger. When I comment that code that runs WS2812_Send() it runs fine and actually toggles the led_PC6.
I have added the new code.
#include "main.h"
#define MAX_LED 8
void HAL_TIM_PWM_PulseFinishedCallback(TIM_HandleTypeDef *htim)
HAL_TIM_PWM_Stop_DMA(&htim1, TIM_CHANNEL_1);
data_sent_flag=1;
void Set_LED (int LEDnum, int Red, int Green, int Blue)
LED_Data[LEDnum][0] = LEDnum;
LED_Data[LEDnum][1] = Green;
LED_Data[LEDnum][2] = Red;
LED_Data[LEDnum][3] = Blue;
void Set_Brightness (int brightness) // 0-45
if (brightness > 45) brightness = 45;
for (int i=0; i<MAX_LED; i++)
for (int j=1; j<4; j++)
LED_Mod[i][j] = brightness;
void WS2812_Send (void)
uint32_t indx=0;
uint32_t color;
for (int i= 0; i<MAX_LED; i++)
color = ((LED_Mod[i][1]<<16) | (LED_Mod[i][2]<<8) | (LED_Mod[i][3]));
for (int i=23; i>=0; i--)
if (color&(1<<i))
pwmData[indx] = 60; // 2/3 of 90
else pwmData[indx] = 30; // 1/3 of 90
indx++;
for (int i=0; i<50; i++)
pwmData[indx] = 0;
indx++;
HAL_TIM_PWM_Start_DMA(&htim1, TIM_CHANNEL_1, (uint32_t *)pwmData, indx);
while (!data_sent_flag){};
data_sent_flag = 0;
int main(void)
HAL_Init();
MX_GPIO_Init();
MX_DMA_Init();
MX_TIM1_Init();
Set_LED(1,0,255,0);
Set_LED(2,0,0,255);
Set_LED(3,0,0,255);
Set_Brightness(8);
WS2812_Send();
/* Infinite loop */
uint8_t X = 5;
int8_t flip = 0;
while (1)
HAL_Delay(1000);
if (X == 4){
Set_Brightness(30);
WS2812_Send();
X++;
//WS2812_Send();
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
if (HAL_TIM_PWM_Init(&htim1) != HAL_OK)
Error_Handler();
Error_Handler();
sConfigOC.OCMode = TIM_OCMODE_PWM1;
if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
Error_Handler();
Error_Handler();
#endif
‎2021-09-19 6:11 PM
Define "crashes". When you debug the program, where is execution?
data_sent_flag should be volatile.
