How to save variables to a file (csv or similar) using expressions
2023-05-25 12:53 AM
I am running a STM32L412 and am trying to debug some ADC samples, this is done by saving to a dbg_ADC[2000] after ADC sampling, the program is then halted and the expressions are copied out. Currently with version 1.10.1 it crashes too often, sometimes i can copy out 1000 samples and other times i can copy out just a few hundred before crashing and need to restart the program, this happens on all PCs.
So the question is, is there a better way to save expressions/variables/ADC samples to a file for later analysis?
ADC
STM32CubeIDE
STM32L4 series
2023-05-26 3:36 AM
Hello @TLinq.1
I may suggest the usage of Serial Wire Tracing to trace the needed data.
For more detail check the 4.2 SWV debugging section from the STM32CubeIDE user guide.
KR,
Semer.
2023-05-26 3:36 AM
Hello @TLinq.1
KR,
Semer.
