how to read and write data to USART_DR register without using HAL
SGupt.17
I am using this as
unsigned char USARTReadChar()
while(!(USART_SR_RXNE));
return USART_DR;
void USARTWriteChar(char data)
USART_DR = data;
while(!(USART_SR_TXE));
Build report has 4 errors, 1 warning
please suggest
Build Report:-
15:05:44 **** Build of configuration Debug for project USART test ****
make -j4 all
arm-none-eabi-gcc -mcpu=cortex-m3 -g3 -c -I../ -x assembler-with-cpp --specs=nano.specs -mfloat-abi=soft -mthumb -o "Startup/startup_stm32f103c8tx.o" "../Startup/startup_stm32f103c8tx.s"
arm-none-eabi-gcc "../Src/main.c" -mcpu=cortex-m3 -std=gnu11 -g3 -DUSE_HAL_DRIVER -DSTM32F103xB -DDEBUG -c -I../Inc -I../Drivers/CMSIS/Device/ST/STM32F1xx/Include -I../Drivers/CMSIS/Include -I../Drivers/STM32F1xx_HAL_Driver/Inc/Legacy -I../Drivers/STM32F1xx_HAL_Driver/Inc -O0 -ffunction-sections -fdata-sections -Wall -fstack-usage -MMD -MP -MF"Src/main.d" -MT"Src/main.o" --specs=nano.specs -mfloat-abi=soft -mthumb -o "Src/main.o"
arm-none-eabi-gcc "../Src/stm32f1xx_hal_msp.c" -mcpu=cortex-m3 -std=gnu11 -g3 -DUSE_HAL_DRIVER -DSTM32F103xB -DDEBUG -c -I../Inc -I../Drivers/CMSIS/Device/ST/STM32F1xx/Include -I../Drivers/CMSIS/Include -I../Drivers/STM32F1xx_HAL_Driver/Inc/Legacy -I../Drivers/STM32F1xx_HAL_Driver/Inc -O0 -ffunction-sections -fdata-sections -Wall -fstack-usage -MMD -MP -MF"Src/stm32f1xx_hal_msp.d" -MT"Src/stm32f1xx_hal_msp.o" --specs=nano.specs -mfloat-abi=soft -mthumb -o "Src/stm32f1xx_hal_msp.o"
arm-none-eabi-gcc "../Src/stm32f1xx_it.c" -mcpu=cortex-m3 -std=gnu11 -g3 -DUSE_HAL_DRIVER -DSTM32F103xB -DDEBUG -c -I../Inc -I../Drivers/CMSIS/Device/ST/STM32F1xx/Include -I../Drivers/CMSIS/Include -I../Drivers/STM32F1xx_HAL_Driver/Inc/Legacy -I../Drivers/STM32F1xx_HAL_Driver/Inc -O0 -ffunction-sections -fdata-sections -Wall -fstack-usage -MMD -MP -MF"Src/stm32f1xx_it.d" -MT"Src/stm32f1xx_it.o" --specs=nano.specs -mfloat-abi=soft -mthumb -o "Src/stm32f1xx_it.o"
../Src/main.c: In function 'USARTReadChar':
../Src/main.c:209:10: error: 'USART_DR' undeclared (first use in this function); did you mean 'USART_DR_DR'?
 return USART_DR;
     USART_DR_DR
../Src/main.c:209:10: note: each undeclared identifier is reported only once for each function it appears in
../Src/main.c: In function 'USARTWriteChar':
../Src/main.c:213:2: error: 'USART_DR' undeclared (first use in this function); did you mean 'USART_DR_DR'?
 USART_DR = data;
 USART_DR_DR
../Src/main.c:210:1: warning: control reaches end of non-void function [-Wreturn-type]
make: *** [Src/subdir.mk:33: Src/main.o] Error 1
make: *** Waiting for unfinished jobs....
"make -j4 all" terminated with exit code 2. Build might be incomplete.
15:05:46 Build Failed. 4 errors, 1 warnings. (took 2s.406ms)
2 REPLIES 2
Figure out whatever macros you're using, and see what others are provided.
Here we just use the form
USART1->DR = data;
unsigned char USART1ReadChar(void) {
  while(!(USART1->SR & USART_SR_RXNE));
  return USART1->DR;
void USART1WriteChar(char data)  {
  USART1->DR = data;
   while(!(USART1->SR & USART_SR_TXE));
assuming you want to use USART1.
