2020-04-19 03:22 AM
I tried to do it the same way it is for Eclipse but it is not detecting the SConstruct or taking the Python Library
2020-04-19 12:57 PM
CubeIDE is Eclipse. How it works in your Eclipse? Does your scons run on Jython included in Eclipse, or on external CPython?
-- pa
2020-04-19 09:40 PM
Hi Pavel, thanks for responding.
2020-04-20 07:53 PM
Then probably it can work as "makefile" type project. Instead of "make" specify your script as the build command.
-- pa
2020-04-21 03:48 AM
yeap I did that, still not accepting
