How to change the Repository directory (location)?
SKled.1
Senior II
By default, in Windows, STM32CubeIDE downloads all firmware dev packages for all MCUs used into a Repository folder under the User folder for the user installing it, e.g.: C:\Users\User Name\STM32Cube\Repository.
I don't want it there, actually not even on that drive at all.
How do I change that Repository path?
Wijeden RHIMI
Hi @Community member​ ,
Under Window --> preferences , then try to do the same thing as shown in the screenshot bellow:
Don't hesitate to ask more questions.
Thanks,
Wijeden,
5 REPLIES 5
Bob S
Principal
I haven't tried this, and I don't run CubeMX from inside IDE, but....
In standalone CubeMX go to Help->Updater Settings. There is a field for repository folder. Try that.
Wijeden RHIMI
Thanks,
Wijeden,
SKled.1
Senior II
Ah, thanks. It's under Window here, not Project.
Wijeden RHIMI
Hi @SKled.1
Yes yes under window sorry 🙂
Does this solution solve your issue ?
Wijeden,
SKled.1
Senior II
Yep 😉
