Failed to execute MI command
2019-09-17 3:33 PM
I am trying to debug my hardware for the first time. I was working in TrueStudio 9.3.0 as I had started this project in it before STM32CubeIDE came out. When I started to try to debug my program to day I got an error. OK, maybe I should try STM32CubeIDE instead. Loaded this up and got the project migrated with no problem. But when I go into the debugger it generates the same error and exits. I am not sure where to start to track this down. The console shows this:
STMicroelectronics ST-LINK GDB server. Version 5.2.3
Copyright (c) 2019, STMicroelectronics. All rights reserved.
Starting server with the following options:
Persistent Mode : Disabled
Logging Level : 1
Listen Port Number : 61234
Status Refresh Delay : 15s
Verbose Mode : Disabled
SWD Debug : Enabled
Waiting for debugger connection...
Debugger connected
Debugger connection lost.
Shutting down...
The detailed error message gives me this:
Error in final launch sequence:
Failed to execute MI command:
target remote localhost:61234
Error message from debugger back end:
Remote communication error. Target disconnected.: Success.
I am using an ST-LINK\V2. I can download the program just fine using STM32CubeProg so I know the ST-LINK and the interface is working correctly. Where do I go next to figure this out? Thanks.
STM32CubeIDE
2020-03-30 4:55 AM
Your luck may vary.
Lawrence
2020-03-31 4:32 AM
I solved my problem. Firstly, I deleted Keil IDE and then upload it again. Secondly, I downloaded necessary packs and driver. Thus , I solved problem :)
2020-05-14 5:04 AM
I am getting exactly the same problem. A program using the Nucleo-64 with STM32L073RZ gives no problems, another program, even a blank new project, with Nucleo-64 with STM32L476RG gives
"Failed to execute MI command:
target remote localhost:61234"
2020-10-01 12:59 PM
I am using STM32CubeIDE 1.4.2, a Nucleo STM32F072RB, and the ST-LINK GDB server debugger.
I had a project that worked fine. I created a new project to test a weird issue I was having with the other project, and had no problems (no error, no weirdness). When I went back to the original project - I started getting this error about the .elf file. I tried everything - I spent more than half a day on the #$%^ing thing.
What ended up working for me (your results may vary) was copying the STM32F072RBTX_FLASH.ld file from the working project to the broken project. My original project never had it (I checked my git history), but for some reason when I copied it from the working project to the broken project - problem fixed.
I'm not sure whether that's THE fix, or one element in everything else. The original project had a .cfg file the new project never had, and I definitely cleared out files created by debugging to reset them. None of those on their own fixed it.
I think some setting was changed when I created the new project and it affected the original.
Good luck!
2021-03-09 7:16 AM
Erasing the whole flash using Stm32Cubeporgrammer has helped me to solve this problem
2021-06-08 7:26 AM
Hello, I hope someone had an answer to this problem since it was posted a year ago. I am currently trying to program an STEVAL-ESC001v1 board with an STLINK V2 ISOL probe. The IDE I use is the STM32CubeIDE. Before that, I used a regular STLINK V2 probe and the debugging of my program worked perfectly. Ever since I switched to the STLINK V2 ISOL (for isolation from power), I have been getting these errors on the console :
STMicroelectronics ST-LINK GDB server. Version 5.8.0
Copyright (c) 2020, STMicroelectronics. All rights reserved.
Logging Level : 1
SWD Debug : Enabled
InitWhile : Enabled
Debugger connected
Target is not responding, retrying...
Shutting down...
I tried using the STM32CubeProgrammer software, but It seems like the ISOL probe doesn't recognize the target :
Can anyone help me out with this issue ? Thank you very much
2021-12-13 6:49 AM
Thanks! Your first hint had solved the problem on my HW-setup (ST-Link V3 on STM32U5 board). After setting the ST-Link speed at min. (constant value, not auto), the problem did not occur, so far.
2023-12-16 7:23 AM
I too am getting the same problem.
The things I have noticed are:
1. A lot of us are getting this problem.
2. Those lucky enough to solve it did it entirely with no help from STM.
3. The solutions they found seem weird, random and all over the place with no consistent pattern.
For me, I had a perfectly healthy project with lots of files. My Windows10 PC died and I replaced it with Windows 11.
When I ran STM CubeIDE, I was forced into upgrading the project.
Details of error message "Failed to execute MI command" are next to useless:
load ...\\SDV1B\\Debug\\SDV1B.elf
Error finishing flash operation
2023-12-16 8:47 AM
@BillE After upgrade of Windows, please check the USB connection to the board (the drivers... you know). Use the CubeProgrammer, as other people did above, or other program that works with ST-LINK. Validate that it can connect to the board and load a program.
2025-01-20 11:29 PM - edited 2025-01-21 10:27 PM
I designed a PCB using the STM32F410 microcontroller. Initially, when I tried to download code using the ST-Link V2, I encountered the same problem repeatedly.
To troubleshoot, I pressed the Reset button on my PCB before starting the debugging process with STM32CubeIDE. As STM32CubeIDE attempted to connect to my PCB, I released the Reset button. This method sometimes allowed me to successfully download the code, but it mostly failed.
Next, I added a 10K pull-up resistor to the SWDIO line and a 10K pull-down resistor to the SWCLK line. With these modifications, I was able to successfully download the code 100% of the time without needing to press the Reset button at all.
Interestingly, the same ST-Link V2 worked flawlessly with another STM32F103 PCB board I purchased online. There was no need to press the Reset button during the download process, and this board did not have any pull-up or pull-down resistors on the SWDIO/SWCLK lines.
My conclusion is that the pull-up and pull-down resistors have a significant impact on the SWD connection, but this impact varies depending on the specific version of the STM32 microcontroller.
罗卫华 2025.1月
2Days Later, when I attempted to run the debug session with CubeIDE, I cannot connect to my target board, received the same error. But download function is OK. Then I checked my PCB design, I found a issue. The SWDIO/SWCLK from MCU are firstly connected to a 4pin connector, and then routed to a usb type-c connector. These unused extra lines have significant impact on the communication with STLINK V2. Then I cut them from the 4pin connector, the Debug function ran just quite stable.
My conclusion: 1. SWD wires must be pulled up or down. 2. There couldn't be any stub on the SWD trace.
