expected ';' before '{' token error
DRicc.2
I'm using the book Nucleo Boards programming with the STM32Cube IDE and none of the code in the book seems to ever work. I've attached a text file of the code I created straight from the book but it won't compile because of the error "expected ';' before '{' token error"
3 REPLIES 3
Where?
Post the whole compiler output.
RBENF.1
Hello @DRicc.2​ ,
It seems you have extra underscores in your HAL_GPIO_WritePin calls
Ryan
That seemed to fix the issue, thank you!
