DSP include files errors
‎2024-06-03 7:03 AM
I'm trying to implement the DSP functions, FFT...but including the "DSP include files" I get several errors:
May you help me ?
Thank you, Luigi
- Labels:
STM32CubeIDE
‎2024-06-03 9:30 AM
Hello @carloV ,
Please try to copy source folder from <STM32Cube_Repository>\STM32Cube_FW_H7_V1.11.2\Drivers\CMSIS\DSP\Source to your project as shown in the below figure.
Keep only the folders containing the functions you've used in your project.
After checking the errors in your screenshot, I think you need to keep only "TransformFunctions" and "CommonTables" folders (Please check if you need to keep other source folders).
Open "CommonTables.c" file in CommonTables folder and comment all includes:
#include "arm_common_tables.c"
#include "arm_const_structs.c"
Open "TransformFunctions.c" file in TransformFunctions folder and comment all includes:
#include "arm_bitreversal.c"
#include "arm_bitreversal2.c"
#include "arm_cfft_f32.c"
#include "arm_cfft_q15.c"
#include "arm_cfft_q31.c"
#include "arm_cfft_radix2_f32.c"
#include "arm_cfft_radix2_init_f32.c"
#include "arm_cfft_radix2_init_q15.c"
#include "arm_cfft_radix2_init_q31.c"
#include "arm_cfft_radix2_q15.c"
#include "arm_cfft_radix2_q31.c"
#include "arm_cfft_radix4_f32.c"
#include "arm_cfft_radix4_init_f32.c"
#include "arm_cfft_radix4_init_q15.c"
#include "arm_cfft_radix4_init_q31.c"
#include "arm_cfft_radix4_q15.c"
#include "arm_cfft_radix4_q31.c"
#include "arm_cfft_radix8_f32.c"
#include "arm_dct4_f32.c"
#include "arm_dct4_init_f32.c"
#include "arm_dct4_init_q15.c"
#include "arm_dct4_init_q31.c"
#include "arm_dct4_q15.c"
#include "arm_dct4_q31.c"
#include "arm_rfft_f32.c"
#include "arm_rfft_fast_f32.c"
#include "arm_rfft_fast_init_f32.c"
#include "arm_rfft_init_f32.c"
#include "arm_rfft_init_q15.c"
#include "arm_rfft_init_q31.c"
#include "arm_rfft_q15.c"
#include "arm_rfft_q31.c"
Please refer to step 4, 5, 6 and 8 under this FAQ: How to integrate CMSIS-DSP libraries on an STM32 p... - STMicroelectronics Community
I hope this help you!
Please let me know if the issue is solved or not?
Thank you.
Kaouthar
‎2024-06-03 9:06 AM
Linker Errors
Make sure your compiler build options for FPU and register ABI (hard / soft) are consistent with those of the library which you're attempting to bind against.
‎2024-06-03 9:24 AM
‎2024-06-03 9:30 AM
Hello @carloV ,
Thank you.
Kaouthar
‎2024-06-04 12:15 AM
Thank you Kaouthar,
I've solved the issue.
Luigi
