Does STM32Cube IDE require internet to operate?
‎2024-07-16 4:09 AM
Once the IDE is installed, is connection to the internet required while using it ?
‎2024-07-16 4:56 AM
No, you don't need the internet to build or run projects.
You do need the internet to download firmware packages.
‎2024-07-16 4:15 AM
It depends what version you have!
I think it was 1.15.x which introduced the requirement to login?
That's why I've stuck with 1.13.0!
Also depends on what you mean by "operate"; eg, when starting a new project, it might need to download a new firmware pack - but once that's done, it's done.
‎2024-07-16 4:19 AM
Thank you for the reply.
Latest version 1.16 is the one I am referring to.
By operate I mean to build and run projects
‎2024-07-16 4:56 AM
‎2024-07-16 4:57 AM
Perfect, thank you!
‎2024-07-16 5:19 AM - edited ‎2024-07-16 5:20 AM
But it's possible to download them manually from the ST website as zip files(requires account ,grrrr) and then install them offline on another machine (via Help/Manage Embedded Software Packages/From Local).
- Please post an update with details once you've solved your issue. Your experience may help others.
‎2024-07-16 5:22 AM
Thank you Barry. So essentially, one can download everything needed and then once installed one can go off-line. Great stuff!
