display double / longlong in cube IDE debugger?
Ihawk.1
How can I display double or longlong variables (as human readable floating point or integer values) in the cube ide debugger please?.
Guru
Same way as you view any other variable. View them in Variables or add them to Expressions as desired. What issue are you running into?
Guru
IHawk
Harrumph (shuffles feet awkwardly) - yes, that does indeed work. Quite why it didnt appear to be working the other night I don't quite understand. Thankyou!
