CubeMX behavior when open from CubeIde.
JAlca
Senior
Hi all!,
I notice a different behavior from CubeMX, when starts alone or is called from CubeIDE.
When I open CubeMX without CubeIDE, it works as espected. But when CubeMX is open from CubeIDE, it works in a strange way. Per exemple, when I try to put a MCU reference, with every key I stroke it tabs to "search" entry.
Anyone with the same problem?
Aftermore, this strange behavior happens sometimes, and sometimes dont...
Here, CubeMX opened directly:
and here opened from CubeIDE:
My CubeIDE version:
Hello again @JAlca
This is a known limitation (number 191199 on our errata wiki https://wiki.st.com/stm32mcu/wiki/STM32CubeIDE:STM32CubeIDE_errata_1.16.x#Limitations). To avoid it you need to reinstall STM32CubeIDE from the installer on st.com.
Best Regards.
STTwo-32
3 REPLIES 3
STTwo-32
Hello @JAlca
Could you please try to uninstall and install again both CubeMX and CubeIDE. I think this problem will disappear
Best Regards.
STTwo-32
Hi!,
And thank you for yyour fast response.
Yes, you're right. If I uninstall/reinstall, the problem disappears, but after a time I have again that problem. It happened to me a bunch of times.
Hello again @JAlca
Best Regards.
STTwo-32
