CubeIde 1.15.1 moves cursor when tying part number for new project
‎2024-05-08 4:25 AM
when creating a new project, and I start typing in the "Commercial Part Number" field, the cursors moves to another field after the first character.
Here I was trying to type "Nucleo" and the cursor moved to the other filed after the first keypress.
‎2024-05-10 1:14 AM
I reported this internally for further investigation.
Internal ticket number: 180961 (This is an internal tracking number and is not accessible or usable by customers).
Thank you.
‎2024-05-08 8:30 AM
I didn't reproduce the behavior with 1.15.1:
When I type N the text is kept in the field and list of available devices occurs.
Could it be something related to your keyboard? did you try the same on another PC?
‎2024-05-09 11:10 PM
I've experienced the same problem.
I'm using windows 11,
cube ide Version: 1.15.1, which is upgraded from 1.12.1.
Build: 21094_20240412_1041 (UTC).
‎2024-05-09 11:24 PM
@Sarra.S another user is facing the same behavior. Unfortunately I can’t reproduce it.
‎2024-05-10 1:14 AM
Thank you.
‎2024-05-15 1:27 AM
I have also updated Cube 1.15.0 to 1.15.1, maybe that could be a hint.
‎2024-05-15 1:33 AM
Do you confirm that the behavior has disappeared with V1.15.1?
‎2024-05-20 2:59 AM
quite the contrary: I do have it on 1.15.1, and a colleague of mine does too.
Thinking back, I don't think I had it when I installed 1.15, but it appeared after the update.
Can you try to install first 1.15 then update to 1.15.1 and check the behavior that you get?
Marco
‎2024-05-20 3:02 AM - edited ‎2024-05-20 3:04 AM
Hello @MD,
This issue has been identified and reported to the CubeIDE development team, and will be fixed ASAP!
Edit: yes, the issue is identified after the update from CubeIDE 1.15.0 to 1.15.1
Thank you
‎2024-08-20 1:37 AM
Hello everyone,
This issue is fixed in STM32CubeIDE 1.16.0 release which published on ST.com.
BR
