could not edit MCU GCC Compiler
Monika_02
Hello, As I am testing the code, I don't require -fcyclomatic-complexity option that is mentioned in Properties->C/C++ Build->Settings->MCU GCC Compiler->All options.  But I could not edit this column how can I remove this  -fcyclomatic-complexity. I have attached the screenshot of the same below.
Thanks & Regards,
Monika
JTP1
Lead
Hello Monika
you can disable this functionality here:
Br. J.T
4 REPLIES 4
JTP1
Lead
Hello Monika
Br. J.T
Monika_02
Thank you so much for your timely response.
Monika_02
Is it possible to get the .o files i.e. the output files in the same folder because whenever I build the code it gets save in the Debug folder.
JTP1
Lead
Hello
You allready seem to got answers to other thread you started about this matter 👍
Br J.T
