2023-07-28 12:18 AM
Hello, As I am testing the code, I don't require -fcyclomatic-complexity option that is mentioned in Properties->C/C++ Build->Settings->MCU GCC Compiler->All options. But I could not edit this column how can I remove this -fcyclomatic-complexity. I have attached the screenshot of the same below.
Thanks & Regards,
Monika
2023-07-28 12:33 AM
2023-07-28 12:33 AM
Hello Monika
you can disable this functionality here:
Br. J.T
2023-07-28 1:48 AM
Thank you so much for your timely response.
2023-07-28 1:59 AM
Is it possible to get the .o files i.e. the output files in the same folder because whenever I build the code it gets save in the Debug folder.
2023-07-28 8:58 AM
Hello
You allready seem to got answers to other thread you started about this matter :thumbs_up:
Br J.T
