CAN communication between two microcontrollers
‎2023-11-25 4:28 AM
Hi, I am using STM32F373C8 micro controller. I am using CAN interface between the two controllers. I want to know with CAN Transceiver, is it possible to establish communication between them?
‎2023-11-25 6:38 AM
Yes, two microcontrollers with CAN can talk to each other.
‎2023-11-25 9:10 AM
Sure, use a transceiver, use some diodes, couple of ways to get it done.
Examples, perhaps look at the EVAL series boards, examples available for those, schematics, etc. Check Keil's app notes about a simple bus using diodes
‎2024-07-09 5:29 AM
Yes, You Can.
I am also working on the same project, we can connect.
Message me
