STM32CubeProgrammer v2.19 released
‎2025-03-03 12:40 AM - edited ‎2025-05-15 1:58 AM
We are pleased to announce that STM32CubeProgrammer 2.19 is available
What is new in 2.19:
- Support for the STM32WBA6xxx microcontrollers:
- Internal memory programming
- Option byte/OTP programming
- RDP regression with password
- SFI support
- Support for MCE Noekeon encryption for STM32H7R3/7S3 and STM32H7R7/7S7 microcontrollers
- Performance enhancement: support for incremental programming
- Support for endianness management in automatic serial numbering
- Added key wrapping using coupling and chaining bridge (CCB), supporting DUA key, for the STM32U3
series microcontrollers - Support for flash programming via J-Link for the STM32WB0 series microcontrollers
- X-CUBE-RSSe and STM32MPUSSP-UTIL packages install and update from server
- Support for multiple boards for debug authentication
Main fixed issues in 2.19:
Refer to the STM32 microcontroller wiki at:
https://wiki.st.com/stm32mcu/wiki/STM32CubeProgrammer_errata_2.19.0
Known problems and limitations in 2.19:
How to get STM32CubeProgrammer 2.19:
- Under this link
- Or update your current installation of STM32CubeProgrammer using: Help > Software update
- Labels:
STM32CubeProgrammer
‎2025-05-02 4:08 AM
Just a small FYI: The links to the errata is wrong, it points to the errata of CubeMX and not CubeProgrammer. So the shown text has the right address, but when clicked it actually links to the wrong page.
‎2025-05-05 1:05 AM
Thanks for the heads-up @EBotö.1, link changed accordingly.
Aziz
