CAN communication between two microcontrollers
Hassanfraz
Hi, I am using STM32F373C8 micro controller. I am using CAN interface between the two controllers. I want to know with CAN Transceiver, is it possible to establish communication between them?
3 REPLIES 3
Yes, two microcontrollers with CAN can talk to each other.
Sure, use a transceiver, use some diodes, couple of ways to get it done.
Examples, perhaps look at the EVAL series boards, examples available for those, schematics, etc. Check Keil's app notes about a simple bus using diodes
Raj8658
Yes, You Can.
I am also working on the same project, we can connect.
Message me
