Build terminate with exit code -1.
‎2024-01-31 6:35 AM
Hi All,
I compiled my code, no error no warning, but I get this code below. Also, when I try to run the code, it is not uploaded to the board.
Could you pls check for me ?
**** Incremental Build of configuration Debug for project Boot ****
make -j8 all
arm-none-eabi-size Boot.elf
text data bss dec hex filename
31800 404 8420 40624 9eb0 Boot.elf
Finished building: default.size.stdout
"make -j8 all" terminated with exit code -1. Build might be incomplete.
‎2024-01-31 6:55 AM
It looks like it thinks there's nothing to build.
Try doing a 'Clean' first:
‎2024-01-31 8:03 AM
Thanks for the reply.
I did what you suggested, please see the attachment first. Then, I performed build but I still get the same error as in the second attachment.
‎2024-06-12 4:35 AM
Is there a solution already? I ran into the same Problems and my Environment seems to be illformed, whereas other PC's are able to Execute the same binaries....
‎2025-04-07 5:56 AM - edited ‎2025-04-07 6:01 AM
Hi @demir ,
I am getting the same error while clean build and incremental build as well.
I am getting the below error & the STM32 DISC1 board is not getting flashed.
During flashing it is getting stuck after 52%.
I tried removing parallel build as well, but still same issue.
But the same board same environment working fine for me, few months back.
Please let me know, if you got any solution.
Thank You..
