ADC Triggered by Timer
SA  V.1
Hello community , Am using STM32H745ZIT6 MCU in that  configured ADC (4 channnels)  triggered by timer and data collected in DMA .ADC is tiggered by timer (all the 4 channels at a time ) . I want to trigger each channels seperately(in a single ADC) by using different timer or timer channels and collect the data in DMA  this case is possible to do .???   If Yes? any Suggestion . if NO ? Why ?
SofLit
From architectural point of view it's not possible to trigger different channels of the same ADC with different timers. Because you can only select one event at a time:
From the reference manual
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
1 REPLY 1
SofLit
