1. How can we watch the PWM signal output in the Stm32 cube ide ?
2. How can we watch UART serial-based output console in the STM32 cube ide?
‎2023-03-21 12:01 AM
I need answers with producer for above queries for learning about stm32 mcus with stm32 cube ide.
STM32CubeIDE
TIM
UART-USART
‎2023-03-21 1:56 AM
- PWM signal :
Check the signal with an Oscilloscope.
- UART console
Create a new Command Shell Console.
Configure the new Console just as you did with PuTTY.
- Also, You can too open a console emulator such as TeraTerm. Configure the console baud rate and data bits length. The COM Port name may differ on your PC.
Foued
‎2023-03-21 1:56 AM
- PWM signal :
- UART console
Foued
‎2023-03-21 2:07 AM
Regarding PWM watching console, does not have any inbuilt console in stm32 cube ide?
‎2023-03-21 2:17 AM
For the UART communication, check this link :Getting started with UART - stm32mcu (stmicroelectronics.cn)
PWM: try to debug ,check the value of the registers and get the results via an Oscilloscope.
Hands-On with STM32 Timers: Complementary Variable Frequency PWM - Bing video
