when i use STMCubeMX(version6.8.0) to generate the code about STM32MP157DAA1,i find whether i define the GPIO's user label,it just can't generate in the keil project.
GGree.2
i also find some people say this is a bug,repeatedly click the setting of user label can be solved,but i try it's can‘t figure it out.....
By the way,GPT also not give the correct solution (this is why i am here)​
this is my first question in this commuity,so please forgive the mistake maybe i have done: )
4 REPLIES 4
Olivier GALLIEN
Hi @GGree.2​ ,
From
https://community.st.com/s/question/0D53W00001JX4HNSA1/how-to-make-the-cubemx-generate-the-code-with-the-user-label-given-to-the-ios
and
https://community.st.com/s/question/0D53W00001X2gZ0SAJ/cube-mx-650-the-user-label-has-not-been-set-did-you-forget-something
I understand this feature was buggy in previous version but supposed to work now.
Did you create from scratch or migrating from a previous MX version ?
Can you please share more details about your use case using screenshot ?
Olivier
Olivier GALLIEN
GGree.2
i create from scratch,but it's not work.
0693W00000aPMUMQA4.png0693W00000aPMTFQA4.png0693W00000aPMI8QAO.pngtips:this search is because GPT tell me if the user label exists, there will be appear some words like ".user intt"(something like this) in this file
Olivier GALLIEN
Hi @GGree.2​ ,
Did you assign the GPIO "LED0" to cortex-M4 ?
Olivier
Olivier GALLIEN
i did it but it's not work,however there is something werid,my Pin Reserved of Cortex-M4 is follow a word "FW"
like this
