2024-04-09 7:43 AM - last edited on 2024-04-09 12:19 PM by mƎALLEm
Hello
I tried everything but I cannot get STM32CubeIDE to get the editor to work.
I just keep on getting this message: There is no active editor that provides an outline.
I spent hours re-installing but nothing worked
All help will be appreciated
2024-04-10 1:22 PM
Maybe try old version - afair i had CubeIDE v1.10.0 installed on Win7 .
2025-01-10 3:56 PM
main.c MouseClick returns "no active editor that provides an outline"
Environment: Windows 11. date 11jan2025
Go to windows explorer:
DoubleClick any *.c file. ( or find your actual .. project... main.c file)
WINDOWS ASKS YOU TO "SELECT AN APP TO EDIT THIS main.c FILE
Select NotePad
Close everything
Restart
2025-01-11 12:09 AM
If you have made an IDE-project, it should look like this :
"no active editor that provides an outline" = something is missing, to let the IDE know, what to do.
Is this your first try with this IDE ? -> read the manual, ...first : get started etc.
https://wiki.st.com/stm32mcu/wiki/Category:STM32CubeIDE
https://www.st.com/resource/en/user_manual/um2609-stm32cubeide-user-guide-stmicroelectronics.pdf
2025-01-11 6:15 AM
This was my SOLUTION to the issue discussed. It was NOT a problem description. Sorry for any misunderstanding!
