Should the pin settings in the generated .dts file be written to the .dtsi file?
安保.1
In stm32mp157c-ed1.dts, the MPU pin setting is written in the stm32mp15-pinctrl.dtsi file, but in CubeMX, a node called @pinctrl is created in the generated .dts file and written in it.
Why?
Can I delete this part and create a ***.pinctrl.dtsi file?
PatrickF
Device tree structure provided for Starter package and Device tree structure generated by CubeMx are slightly different.
Please have a look to https://wiki.st.com/stm32mpu/wiki/STM32_MPU_device_tree#STM32CubeMX_generated_device_tree
see also
https://wiki.st.com/stm32mpu/wiki/Device_tree
and
https://wiki.st.com/stm32mpu/wiki/How_to_compile_the_device_tree_with_the_Developer_Package
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
PatrickF
see also
and
安保.1
Thank you PatrickF.
Unfortunately I can't find "select as sest".
How to display "select as best" in the name of your answer.
