Help with ADS124S08 SPI ADC and its Linux driver
Lmoio.1
Hi, can someone help with ADS124S08 SPI ADC and its linux driver? I think the driver is correctly probed. I see /sys/devices/platform/soc/44004000.spi/spi_master/spi0/spi0.0/iio.device0/in_voltage0raw ...etc but it seems the device does not reply.
This is my device tree configuration:
&spi1 {
	status = "okay";
	pinctrl-names = "default";
	pinctrl-0 = <&spi1_pins_a>;
	cs-gpios = <&gpioz 3 GPIO_ACTIVE_LOW>;
    #address-cells = <1>;
    #size-cells = <0>;
        adc@0 {
            compatible = "ti,ads124s08";
            reg = <0>; /* CS #0 */
            spi-max-frequency = <1000000>;
            spi-cpha;
            reset-gpios = <&gpioi 2 GPIO_ACTIVE_LOW>;
First, i don't see the cs going low when i try to read the voltages. Should the driver do that?
Second, the driver ti-ads124s08.c itself seems a bit incoherent with the datasheet. it defines the start conversion command as in the datasheet but then never uses it and instead it uses a made-up command.
#define ADS124S08_CMD_START	0x08
#define ADS124S08_START_CONV	0x01
ret = ads124s_write_cmd(indio_dev, ADS124S08_START_CONV);
		if (ret) {
			dev_err(&priv->spi->dev, "Start conversions failed\n");
			goto out;
Lmoio.1
Hi @PatrickF​
i managed to make it work; linux driver is bugged and very basic and cannot handle the whole behaviour of the device. So i had to modify the driver to write specific registers.
PatrickF
did you enabled the SPI1 kernel clock in the device tree ?
Located in the &rcc node, you should have something like :
st,pkcs = <
      CLK_SPI2S1_XXXX <== could be PLL4P, PLL4Q, CKPER or PLL3R
could be checked in /sys/kernel/debug/clk/clk_summary by using such kind of command :
grep -E "clock|spi" /sys/kernel/debug/clk/clk_summary | sed 's,\s\+, ,g' | column -t
Patrick
Lmoio.1
Hi @PatrickF​
Dear Lmoio,
Could you share with us the driver.
Thank you very much,
Best Regards,
Issam
