Clarification Regarding TSN Ethernet in STM32MP257-DK Board
Aks
Hello
We are Working on STM32MP257F-DK Board.We would greatly appreciate your help if you could help us with the following doubts:
  • We Would like to How to disable ON-Board ST-link and Set it to J-LINK Mode
  • We want to Check  Ethernet using build root in this board.We would like to how to identify if TSN is enabled in Linux and u boot?.If not enabled how to do it in Linux.
Thanks & Regards
Akshitha Pattem
4 REPLIES 4
ahsrabrifat
Olivier GALLIEN
Hi @Aks
There's no alternative to on-board ST-Link on STM32MP257F-DK.
You might consider to get a STM32MP257F-EV board where JTAG signal are accessible on MIPI10 connector
For TSN maybe following link can help
How to configure TSN switch - stm32mpu
How to configure TSN endpoint - stm32mpu
Hope it help
Olivier
Olivier GALLIEN
Hello @Olivier GALLIEN
Thanks for response. I Would Check TSN and update you regarding it.
Thanks & Regards
Akshitha Pattem
The J-Link "conversion" is provided by Segger - it's nothing to do with ST - so you would need to contact Segger about that:
https://www.segger.com/products/debug-probes/j-link/models/other-j-links/st-link-on-board/
https://www.segger.com/support/technical-support/
https://forum.segger.com/index.php/Board/3-J-Link-Flasher-related
