2025-03-21 1:56 AM - edited 2025-03-21 3:50 AM
This question is a based on of a support ticket due to more knowledge persons from ST may answer this on the forum. Hope someone can help.
2025-03-21 10:10 AM - edited 2025-03-21 10:15 AM
Receptacle on both EV/DK board are the one listed in board BOM, e.g.
CN2 | Socket_FFC/FPC, 40pins, 0.5mm, RA, SMD, T=1mm | I-PEX | 20455-040E-76 |
Display use JAE HD1S040HA1
The LVDS cable is stated using 2 x JAE HD1P040MA1 or equivalent plug connectors.
Cannot answer for other points, but I think the pinout come from LCD manufacturer (as we use an almost standard display).
Regards.
Regards.
2025-03-24 8:09 AM - edited 2025-03-24 8:13 AM
Thank you very much , This is great information. Kudo X 10 :)
BTW those JAE connectors are listed as NRND's...
