STM32MP15 ECO 5.0.0. Documentation does not provide a information how to create a new FIP
‎2023-08-27 9:30 PM - edited ‎2023-08-29 4:05 AM
As in a different post, The TF-A build did not create the FIP binaries after deleting the FIP build folder.
This article does not describe how to create a new FIP binary. only how to update. very confusing !
The fiptool does provide a create function but its not listed as one the options in this page: very confusing !
How to use the "Create" option ?
- Labels:
Documentation
ST-Boards
STM32MP15 Lines
‎2023-09-15 10:48 PM
Just use the FIP command to build the FIP.bin even it does not exists. works.
‎2023-08-29 8:57 AM
Hello @debugging ,
You are right, we have no complementary explanation for fiptool create command, aside of the fiptool help.
To use it, you just have to do:
fiptool create <name_of_fip>
Then, use fiptool update command to add the different binaries inside, following the article you mentioned.
Kind regards,
Erwan.
‎2023-08-29 5:45 PM
Thanks, this question was raised because the issue I have with the TF-A not creating the fip binaries, so I wonder how to do it manually, but the docs did not define it.
‎2023-08-29 11:19 PM
@debugging ,
I understand. If my previous comment answered your question, please do not hesitate to close this topic with "accepted solution".
Kind regards,
Erwan.
