STM32CubeMX WB55 code generation errors.
RNort
Board: P-Nucleo-WB55
BLE Application Type : Server
Server mode : Custom template
Bug#1: CFG_GAP_DEVICE_NAME always has a "TEMPLATE" value and is independent of the value set in CubeMX.
Bug#2: Routine "Custom_STM_App_Update_Char" was generated with invalid call of "aci_gatt_update_char_value" routine. Instead service handle generated characteristic handle.
P.S. Sorry for terrible English...
3 REPLIES 3
Khouloud ZEMMELI
Hello @RNort​ ,
Thank you for the feedback,
Second bug is confirmed and it will be fixed for the next release, Otherwise for the first big could you please give me more details and share the ioc file ?
Thanks,
Khouloud
RNort
Sure. Take a look.
After code generation file "app_conf.h" contains that:
#define CFG_GAP_DEVICE_NAME       "TEMPLATE"
#define CFG_GAP_DEVICE_NAME_LENGTH   (8)
Khouloud ZEMMELI
Hi @RNort​ ,
You're right , it will be fixed for a next release.
Best Regards,
Khouloud
