How to reduce current consumption on NUCLEO-WL55JC ?
LMesn.1
Hello, i'm using the NUCLEO-WL55JC board.
I am using the LoRaWAN_End_Node example which works fine. However I reach an operating current of around 50mA.
Do you have an idea for a solution?
Have a good day !
Imen.D
Hello @LMesn.1​ ,
The following features are implemented to reduce the current consumption:
  • The core logic is supplied by the low-power voltage regulator to reduce the quiescent current.
  • The Flash memory can be switched off (power-down mode and clock gating) in LPSleep mode. The Flash memory can also be switched off in LPRun mode when the application processor executes from SRAM1.
  • The system clock is limited to 2 MHz. The MSI internal RC oscillator can be selected as it supports several frequency ranges, with a small device total consumption (such as 48 µA in LPSleep, Flash memory off, at 100 kHz).
Please refer to this AN5568 "Ultra-low-power features of STM32WL Series microcontrollers", it may be helpful for you.
Imen
Imen
3 REPLIES 3
Imen.D
Hello @LMesn.1​ ,
Imen
Imen
LMesn.1
Thank you very much, i will try all of this.
Have a good day.
LMesn.1
Hello i applied your advice, and i also changed the supply mode and everything is good. Thank you !
