For STM32WB to start transferring data in file p2p_server_app.c need push button SW1 in the Nucleo board, BUT how was created the variable - "CFG_TASK_SW1_BUTTON_PUSHED_ID"
IRakh.1
I know that "CFG_TASK_SW1_BUTTON_PUSHED_ID" was set in the header file (/app_conf.h), but just set, no more
in the Datasheet the button for Nucleo board SW1 connected to a PC4 pin, but in CubeMX for project "p2p_server" I didn't find any mentions about the button SW1
so, How I can in the custom project to set the variable - "CFG_TASK_SW1_BUTTON_PUSHED_ID" for input PC4 or PC5
for example, see the code here
https://github.com/DavidStdio/STM32WB55_MEMS/blob/3036daab25fe711a5f2f7b37b1537f762bb832ea/Src/p2p_server_app.c
Lubos KOUDELKA
"CFG_TASK_SW1_BUTTON_PUSHED_ID" is variable used by sequencer (simple background scheduler used in STM32 BLE examples). You can find in the repository also simplified example without sequencer used, maybe it could be convenient starting point for your experiments. Please check:
https://github.com/STMicroelectronics/STM32CubeWB/tree/master/Projects/P-NUCLEO-WB55.Nucleo/Applications/BLE/BLE_Peripheral_Lite
Best regards,
Lubos
Lubos KOUDELKA
Best regards,
Lubos
Michael E
Maybe the wiki article will help you on the P to P topic
Michael
