What is the clock rate to be set for LCD-TFT(MHz)?
KMod3
What is the clock rate to be set for LCD-TFT(MHz) and what does the value 1834 indicate? How do we calculate them?0693W00000QL5tHQAT.png0693W00000QL5t7QAD.png
2 REPLIES 2
MM..1
Chief II
Marked refresh count is partof SDRAM config ...
LCD dot clock is based on your LCD pdf plus framerate you use as optimal .
Normal calc is (WIDTH + sync porch ..) x ( HEIGTH + sync porch) x FPS = DCLK
Osman SOYKURT
Hello KMod3,
Sorry I don't know much about this, it's not really related to TouchGFX Designer. If you still need help on this, I suggest you to add more tags to your post for a better visibility.
/Osman
Osman SOYKURT
