2025-02-13 4:08 AM - last edited on 2025-02-13 4:16 AM by Andrew Neil
hello,
I Have linked the Touch GFX folder from another project and the code got compiled while running and Debug I am getting this error.
2025-02-14 5:53 AM
Hello @jijomathew ,
You should try debugging your application as suggested by @Andrew Neil .
By the way, I would not recommend to link your TouchGFX folder from another project because when you generate code in TouchGFX designer it's pointing to a specific folder (STM3CubeIDE folder) inside your application.
See below the lines when you generate code in TouchGFX Designer :
2025-02-21 10:34 AM
2025-02-25 2:39 AM
Hello @jijomathew ,
Have you been able to move on with your issue?
