Touch GFX Hard Fault
jijomathew
hello,
I Have linked the Touch GFX folder from another project and the code got compiled while running and  Debug I am gettingtouchgfxerror.png this error.
11 REPLIES 11
Osman SOYKURT
Hello @jijomathew ,
You should try debugging your application as suggested by @Andrew Neil .
By the way, I would not recommend to link your TouchGFX folder from another project because when you generate code in TouchGFX designer it's pointing to a specific folder (STM3CubeIDE folder) inside your application.
See below the lines when you generate code in TouchGFX Designer :
Osman SOYKURT
Osman SOYKURT
Hello @jijomathew ,
Have you been able to move on with your issue?
Osman SOYKURT
