Touch GFX Hard Fault
jijomathew
hello,
I Have linked the Touch GFX folder from another project and the code got compiled while running and  Debug I am gettingtouchgfxerror.png this error.
jijomathew
  • Yes i was able to resolve the issue, last time there was a mismatch in the project configuration which I was trying to link,
12 REPLIES 12
Andrew Neil
So you're getting a Hard Fault.
How to debug Hard Faults:
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/tac-p/708193/highlight/true#M51
ahsrabrifat
Senior II
In STM32CubeIDE, go to Debug Configurations > Startup > Enable "Fault Exception Handling".
mÆŽALLEm
@jijomathew wrote:
hello,
I Have linked the Touch GFX folder from another project  this error.
Linked to the TouchGFX library created for the same MCU part number?
The linked touch GFX  folder is created for the same MCU.
Thanks and Regards
Jijo
hello ,
I have linked touch GFX folder  to my project from another project its getting compiled but during run its showing hard fault   I will attach the screenshot please help me to overcome this issuetouchgfxerror.png
Are you the same OP of this thread? the same screenshot with almost the same description ..
mÆŽALLEm
Are you the same OP of this threadthe same screenshot with almost the same description ..
 we are both working on a similar project, the similar problem we are facing
mÆŽALLEm
Ok please don't duplicate the same question on more than a thread.
The two threads will be merged.
